Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
Where is the hall sensor of MacBook Air M1?
My Mac can’t sleep when closing lid and I’m sure it’s hall sensor not working.
But I’m quite confused about where is it located precisely.
Score 2
2 Comments
I just wanted to chime in and let you know, that I had the same issue with my MacBook Air M1 not going properly to sleep.. and giving different errors during startup.
After replacing the right speaker, everything worked fine again.
by
Hey, I have the same problem. I've changed the battery in the 2020 mb air. The lid sensor stopped working. Can you please direct me into the thing that i might've been destroyed?
by
Add a comment
1 Answer
Chosen Solution
There are 2. The first is located in the Right Speaker (it's under some foam), and the other is in the microphone assembly.
The pictures I used for the MacBook Air Black Screen troubleshooting page were taken from an M1 MacBook Air for reference.
Score 3
1 Comment:
Do you know if it can be fooled with some magnets?
by
Add a comment
Add your answer
Xuhai Chang will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 80
All Time: 1,580
