Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1418 Questions View all
Trackpad jumps like crazy. Impossible to use.
Hello,
Some months ago the trackpad started to be less responsive. With the time, the problem got worse. Now, it is completely wild, it jumps around and clicks everything without touching it. Trying to control it is just impossible. I have to use it with an external mouse connected all the time.
I have tried almost everything:
The battery is not the problem as the hardware test shows it is ok and it is not bulging, totally plain.
I replaced the trackpad for another one. Nothing went better.
I also reinstalled Lion and reset the complete system after saving all my data and apps into an external disc.
Any thoughts?
Thanks in advance.
P.S: I upgraded the RAM from 2GB to 4GB. The memories were the original ones from a MacBook Pro.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Sounds like the trackpad cable - it passes through a slot in case which can act like a guillotine crimping or damaging the cable as you hammer keys on the case. Some have had luck wrapping the cable with a small piece of paper or tape to protect and stiffen it.
Good Luck,
If this answer was helpful please remember to return and mark it Accepted.
Add a comment
Add your answer
aitordelapera will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,148
