Why does my router tend to drop the connection?
I have a D-Link DI-624 router. However, as of the last year, it has started acting strangely. The hardwired ethernet connections are fine, but anything running on the wireless tends to lose the connection after anywhere from 10-40 minutes. What makes this so strange is that airport still shows it to be connected. The only way to fix the problem is to turn the wireless card in the computer off, then turn it back on.
The same situation occurs on Windows and Ubuntu laptops. All my wireless-equipped laptops suffer from this horrid problem.
I've reset the router multiple times, upgraded the firmware, etc.- nothing seems to work.
Has anyone else had similar problems? Were you able to fix them somehow?
---EDIT---
I forgot to mention that this doesn't happen on my iPhone or iPod. It's always limited to laptops or desktop with wireless. The router came standard with my Verizon FiOS install, so it's probably about 4 years old.
1 Comment
What kind of encryption do you use? WEP, WPA...?
by Crisb
