Can the screen on a apex pro tkl be fixed
Water damage on apex pro tkl and screen doesn’t work anymore
You may be lucky (or unlucky) and that the water only damaged some other components in the keyboard and not the screen itself.
You would have to open the keyboard and inspect the damage.
Maybe not relevant to your particular model but here's a teardown video that may help. (It's the only one that I could find)
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the keyboard's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First disconnect the keyboard to minimize any further damage.
Then you need to dis-assemble the keyboard and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process.Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the keyboard might possibly work correctly again.
Once you have cleaned the keyboard and if the screen still doesn't work, check for any information on the back of the screen itself and use that to try and find suppliers of the screen.
If this process seems too daunting, take your keyboard to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 68
