Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
What is wrong with my computer?
The Magsafe power adapter did not disconnect when pulled on, and the computer made a 2.5 ft fall onto the floor, with the corner connected to the power adapter hitting first. The power adapter slot was dented, and the computer worked, but ran out of battery. The apple store wanted to charge 700+ dollars to fix it, but did not know what was wrong. Following the ifixit guide, I unscrewed the computer and the insides look fine. The power adapter fits now, but there no light appears on any of the power adapters I use. What is wrong with the computer? What should I do?
Score -1
Add a comment
Chosen Solution
Use a multimeter to test the magsafe adapter first to insure its output. Refer to the pinout on the right of this link for voltage. http://en.wikipedia.org/wiki/MagSafe If that's OK the consider replacing the DC-IN board here's how: MacBook Pro 13" Unibody Mid 2010 DC-In Board Replacement
Here';s the part: MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector. Image
Product
$9.99
Score 3
Add a comment
Sounds like the magsafe connector is damaged or loose. Get a magnifying glass and look over that area of the logic board for open, loose or damaged connections. Replacing the magsafe module would be a logical first step. While doing look closely at the logic board to ensure it's not damaged.
Good Luck,
Score 1
Add a comment
Add your answer
E G will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 852
