2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Why is my 2009 MacBook Unibody Screen unaligned with the base?
The screen on my White Unibody MacBook is unaligned by about a millimeter. I've never dropped it or anything, but it is out of warranty, so I can't bring it in to get fixed. I was just wondering if there is a way to align it myself? Here's a link to a thread that I found with a similar issue, but on a MacBook Pro. http://forums.macrumors.com/showthread.p...
Thanks for your help!
Score -1
Add a comment
1 Answer
Chosen Solution
I would try adjusting the hinges. Close the book and see if you can tell which side needs to be moved or has been moved then use this guide to loosen the correct hinge, adjust the the top and re-tighen the display: MacBook Unibody Model A1342 Left Clutch Hinge Replacement
Score 5
Add a comment
Add your answer
Austin Benson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 696
