Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
175 Questions View all
Help identify Tantalum Polymer Capacitor on a2337
I am doing a MacBook air A2337 repair and the NEz CN7 cap is bad and needs to be replaced.
Would like to buy the NEz CN7 and NEy JE8 just in case. I cannot find where to buy these caps alone or even how to look them up. Could someone explain to me how identify then look it up on digikey to buy it. If possible could you leave a digikey link as well so I know what it is for a fact.
Location on Board c5895
Thank you so much for the help!
Score 1
1 Comment
@oldturkey03 whoops! Just added thank you!
by
Add a comment
1 Answer
Chosen Solution
These tantalum caps are notorious for going bad on most generations of MacBook. The capacitor in question is C5800 and is a 33uF 16V in a T Case.
These ones at Mouser look to fit the bill, but you can probably also harvest them off other MacBook boards. Apple seems to love this style of Tantalum cap.
I will also mention, this will probably work just fine without the faulty cap, at least in the short term. If you can replace it safely and easily (which you should be able to in this case), absolutely do so. But it is likely worth it to test that it functions properly without the new capacitor on first so you know that's the extent of the problem before potentially introducing new factors when installing the new one.
I didn't see the other cap mentioned until I reread, but C5895 is a bit different, that's the one in the upper right that you circled in the post. That one is 150uF 6.3V in a B1S-1 case. These ones are a little funkier. But same theory applies. Can harvest off other boards if need be.
Score 2
3 Comments:
Thank you so much for this information! Also the mouser link isn't working for me :(
by
@caboose547 Fixed the link, probably got mangled in a hasty copy paste job. Hopefully it helps!
by
Thank you! I still need help to understand how to search it up on my own for future events as without your link I wouldn't know how to get there.
by
Add a comment
Add your answer
Andy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 247
