How to follow problem?
i don't know how to follow the problem sources
Didn't it list all the likely solutions already? Try the solution section one by one.
sabrallah, correct me if I'm wrong, but it appears you've run a kernel panic analyzer on a phone that is presumably bootlooping every three minutes or so. The analyzer is telling you that the CPU has lost communications with the battery and is listing all the likely causes of that happening. If we could see the same information that analyzer is using then we could give you a better idea of what approach to take to fix the issue.
@flannelist has written an excellent Wiki article on kernel panics and panic logs that describes the source of the data your panic analyzer is using. If you could follow the instructions to access your phone's panic logs and either screenshot or copy/paste the first page or so of the panic log, that will give us more to go on in helping you figure out what's going on with your phone.
That being said, your analyzer is suggesting the following fixes:
Once we can see the panic log you're getting, then we should be able to point you in the right direction. Until then, my personal opinion is that you're probably looking at a fairly straight-forward battery replacement as the fix for your problem, but at this point that's just a guess. Here's an article on editing and adding pictures to your question.
Adding images to an existing question - iFixit Repair Guide
Good luck; let us know what you find!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 50
2 Comments
what mean "swi/i2c bus" ?
by sabrallah youssef
sabrallah youssef, I2C (or I squared C, to be precise) is a bus that allows for communication between devices (in this case between chips (in actuality I2C is a protocol, named Inter-Integrated Circuit, hence I2C).
You need the right equipment in order to debug the information sent on the bus
by Geir Ove Andersen
