Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
Why is my screen displaying weird colors
My 2018 Macbook Pro screen colours started acting weird. I put the laptop to sleep and closed the lid for a few minutes, when I opened the lid to resume work, those green things started popping up on the screen... Areas with plenty of black displays would show like negative or greenish like the image up there...
I am connected to an external monitor and it is displaying fine. What could be the issue
I have restarted it again and again, I have also reset NVRam
It still keeps displaying these weird colours
Score 2
Add a comment
As you only see the problem within the internal display and not the external that proves the issue is within the internal displays logic. This is in fact a common issue when the T-CON board starts to fail from overheating. Apple did a bone heat design here pulling out the T-CON board from within the display lid placing it nearest the hottest area inside the uppercase!
This often happens when you are running your system hard and/or the vents are blocked and/or the fans/heatsink is loaded up with dust so the system is unable to cool it’s self.
Time to open the system giving it a good clean of surface dust on the logic board and bottom cover using a small soft paint brush, then taking out the fans to likewise cleaning then, and lastly cleaning the fin areas of the heatsink using short blasts of can’ed air and giving the other area the same treatment to push the junk out.
Then put your system back together to see if that was all it needed, you might want to install a good thermal monitoring app like TG-Pro which can also push the fans up when the system is running hard (Apple doesn’t push the fans hard enough).
Sadly, if none of this helps you need a new display assembly MacBook Pro 15" Retina (Touch Bar, 2018-2019) Display Assembly and here’s the guide MacBook Pro 15" Touch Bar 2018 Screen Replacement
FYI - The metal covered chips on the circuit board the cables from the lid connect to is the T-CON board which fail.
Replace a display compatible with a 2018 or 2019 model A1990 MacBook Pro 15" with Touch Bar laptop. Includes the 2880 x 1800 15" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, and Clutch Hinges. Image
Product
$534.99
2 Comments:
Which is weird, there is no static wide area defects, instead the weird colors are mostly with the image itself, while the UI elements looked fine, feels like the display is working.
by
@tomchai - This is over saturation (Chroma)
by
Add a comment
The UI parts look absolutely fine so I don't think it's the screen itself, it's most likely a bad GPU or more commonly, a software issue.
Score -1
Add a comment
Add your answer
Oluwafemi Mayungbe will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 18
Past 30 Days: 58
All Time: 2,292
