Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Second hard drive (SSD) does not mount
I used the ifixit kit and a Crucial 128 SSD. I have checked that the drive works fine. But despite all the connexions have been checked twice, the SSD does not mount at all. Disk utility sees nothing.
What's wrong : the connecting cable ? Anything else ?
Score 1
Add a comment
1 Answer
Chosen Solution
Try switching the drives to check out both the drives and the cables.
Score 3
2 Comments:
Excellent suggestion. Did a double-blind switcheraroo (used both cables in both logic board sockets with both drives). Result — The original drive did not work with the kit's cable and the SSD worked with the original cable. Solution, replace the kit's cable.
by
I got a replacement cable for the kit's cable and now everything runs perfectly.
by
Add a comment
Add your answer
gieff will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,888
