Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Question Closed
Replaced iMac hard drive, now no display!
I recently upgraded the hard drive in my iMac 20" 2.0 core duo following the instructions here. Everything went perfectly. Until I tried to boot back up. Now I have no display. I tore down again to double check my connections but they are all fine. The computer starts up, the light comes on, the hard drive spins, the CD drive spins, but no chime (I had it muted on last shutdown), and no gray screen, just black.
Tried resetting PRAM but no luck, tried booting to Install disk, no luck. HELPPP!!!!
Add a comment
1 Answer
Plug into an external monitor to see if your GPU has failed.
1 Comment:
Yes mayer, first step then he should check carefully if there's a faint desktop image on the screen. That would lead to a disconnected inverted cable.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,613
