A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor. Released June 8, 2017.
Can an Additional SSD be installed?
Unit has blade ssd already installed. Is it possible to add an additional sata ssd?
Add a comment
1 Answer
Chosen Solution
Here's what you'll need:
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit
Here's how to do it:
iMac Intel 21.5" Retina 4K Display (2017) Hard Drive Replacement
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21.5" Late 2012-2019 with this SSD upgrade kit. Image
Product
$82.99
Score 2
6 Comments:
@bigmac98 & @mayer You'll also need the cushions and SATA cable as the blade SSD models won't have these.
iMac 21.5" (Late 2013-2017) SATA Cable
Hard Drive Rubber Frame v2
by
@danj If it doesn't already have a drive, will it also need the thermal sensor?
https://eshop.macsales.com/item/OWC/DIDI...
by
@mayer - The 2.5" dive systems don't need the thermal sensor as long as it supports the newer S.M.A.R.T. Services. All current drives are AOK!
by
Thanks for the help Mayer! Much appreciated.
by
@bigmac98 - Don't forget to vote and accept the answer if you're set!
by
Show 1 more comment
Add a comment
Add your answer
Will McCulloch will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 90
