Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
Power button stuck on M1 MacBook Air
Hey!
Does anyone know how I can repair a stuck power button on my M1 MacBook Air? How does the click mechanism work? Would taking it out and putting it back in help? I don't really want to work on my main machine before knowing if that's even an option.
The good thing is, that the power button still works but it's very hard to press and sometimes it gets stuck so the machine is just looping.
Looks like there is dust or something like that under the button, I'm not even sure how exactly it got there.
I would appreciate any help on this. It's making me crazy.
Add a comment
Chosen Solution
You can definitely take it out, which could help. The actual button is on the back side of the Touch ID sensor and it basically presses into a little shim in the top case to activate it. The process is much easier than on an Air than a MacBook Pro to get the button out. Take a look at this Guide for the details. There might be some crud that got in the little well the button sits in causing it to stick.
Score 1
4 Comments:
I fixed it by pressing it really hard, but I am sure that that's not a permanent solution. Should I still take it apart?
by
@cxt That is entirely up to you. Depends on why it was stuck in the first place. But I would say it’s not a bad idea. The only reasons I can think of why it may have been stuck like that would result in me wanting to have a look. If you’re confident in your taking stuff apart skills, and you already have the necessary tools, I would say, do it anyways.
by
@flannelist Well, I'll see. I'm just going to leave it for now, but if it gets stuck again then I will take it apart.
by
@cxt Absolutely fair! Keeping my fingers crossed.
by
Add a comment
There appears to be small aluminum divot underneath the power button that the underside button makes contact with. that appears to be missing from my macbook and I'm not sure why, how, or how to get something to replace it.
Add a comment
Add your answer
cxt will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 122
All Time: 5,705
