Optical Drive doesnt work
I keep getting an error message when trying to burn a disc from iTunes. Something to the effect that the disc is not recognized. Then the cd gets spit out of the machine. Took it into a mac store and they said we needed a new optical drive. I'm looking for a suggestion for which drive to use. Thanks
Score -1
Add a comment
Chosen Solution
You can get this one.
Score 1
Add a comment
Most Helpful Answer
The optical drive may only need a laser lens cleaning. Before buying a new one you could take it out of the machine, open it, dust it off with compressed air and clean the laser lens with isopropyl alcohol.
Score 3
2 Comments:
Aren't there like cleaner disks too you can stick in there?
by
Sure but manual job is always better.
by
Add a comment
Gentlemen..thank you both for your responses. I've sent a disc cleaner thru it several times..still does not work proper. I'll look into the drive you suggested. Thanks again.
Add a comment
Add your answer
Glenn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,002
