Fan always on full, mac slow, I believe it thinks it’s overheating
Hi, I recently bought a MacBook Air 2017, it wouldn’t let me install os so i booted into a external usb and installed from there, however the whole time the fans were on full, I guessed it might be because of the missing software but it didn’t stop after, tried all the usual bug fixes, such as smc reset, nvram reset etc, no difference, on a bench mark it scores around a third of what it should, I saw a thread suggesting trying to turn it on without the trackpad cable and battery connected, so I tried that, no difference, however now the trackpad and keyboard do not function, however the power button still works?
Any ideas how I can go about fixing this? It’s very clean inside, no rust or even dust, and what I believe to be the original battery only has 30 cycles on it, so it’s barely been used from what I can gather.
I might try reseat the trackpad cable again tomorrow in case it helps get the keyboard and trackpad working again
Update (03/23/2022)
Oh, I forgot to add, I did a diagnostic on it before trying to disconnect the cables, results were PFM006 and PPN001. Also tried safe mode and had the same issues
8 Comments
Did you try running the onboard diagnostics? Restart your system and press the D key to enter. Let us know what the error message is
Reference: Mac startup key combinations
If you can you may also what to install a good thermal monitoring app like: TG Pro even the trial version can be useful. Take a snapshot of the main window and post it here for us to see Adding images to an existing question
by Dan
I tried diagnostics, above I posted the error codes, and I also tried macs fan control, there I could get the fans to turn down but the performance was still throttling, all of the thermal sensors were fairly cool and looked normal, I checked them
And all appeared to be working - temperatures fluctuated on all sensors
by Kai Mcpherson
@kaimcpherson - I don't find MacsFanControl that useful as it doesn't offer enough diagnostic info. Please give TG Pro a try as it has what I need.
PPN001 error is telling me you have a bad sensor but without seeing what TG Pro tells us.
by Dan
@danj
Hi, apologies for the delay, thanks for your help with this. I installed the trial and added the photo of the main page, do I need to include any other info from it?
Thanks again
by Kai Mcpherson
Hi Kai,
This likely could be a broken pin/not connected sensor causing this. I have a friend who has a 2017 mba and I'll ask him if he's had a similar behaviour.
by Nick P
Show 3 more comments
