Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
Why does my device turn on and off repeatedly?
I’ve been having this issue since last Monday, my iPhone XR had randomly restarted itself, I pressed the power and volume buttons, hoping a force restart would fix the issue, but it didn’t, the device repeatedly turned on and off by itself, my uncle tried to reset it using their laptop, but it didn’t work, this makes me wonder if the device can be fixed
2 Comments:
It's possible it could be fixed, but more information is necessary. Sounds like it might be experiencing a kernel panic, which is basically just some sort of error the device can't recover from. When you say it turns off and then back on, like it's just restarting randomly? Or it's just stuck looping at the Apple logo? Can you get into it for long enough to check some logs?
If so, they would be in the settings under privacy > Analytics > Analytics data. I would check in that list for any entry that starts with the word "panic" any information on that first screen worth of data when you click on the panic log would be helpful, if any of these sort of logs are present.
by
Despite my iPhone XR not showing the “Storage Almost Full” message, the device restarted itself, and since then it repeatedly turns on and off, what could possibly be the problem?
by
Add a comment
Does it loop apple logo, or it boots to menu then shuts down, if it loops apple logo there must be half-short somewhere , i gues one of the flex cables must have been damaged, try to disconnect all cables one by one to check which may be causing the problem, i suggest start disconnect charging flex then power the phone, if still problem, disconnect cameras and so on until you figure out whats causing problem
1 Comment:
It loop apple logo
by
Add a comment
Well this video might be helpful for you: https://www.youtube.com/watch?v=BsBxwATJ...
Add a comment
It happen since last night
Update (06/18/24)
Happened since last night
Add a comment
Add your answer
Stinger Solar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 60
All Time: 2,546
