Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
My MacBook wont power on at all.
I replaced a broken hard drive and now the computer wont turn on at all. When I plug in the magsafe a green light comes on and the battery is fully charged but when I hit the power button nothing happens. Please help.
Score -1
1 Comment
so i can turn the computer on by shorting out the pins. so i replaced the upper case cable and still the power button wont work. is there anything else i could check or change or do i have to replace the upper case now?
by
Add a comment
1 Answer
Chosen Solution
You seem to have located the problem, it's not getting a start signal from the power button on the upper case. An easy test for a professional with a spare upper case becomes a costly one for you if you don't have one. See if you can find find a local repair guy that will test it out for you on the cheap.
Score 4
Add a comment
Add your answer
ogbta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 675
