Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1017 Questions View all
boot up problem, black screen with question mark
I have a PowerBook G4. When you power up you get the apple symbol for a second but then you get a small folder icon in the middle of the screen with a ? mark in the middle of the folder icon....any ideas?
1 Comment
Go here for help identifying your Mac, http://www.ifixit.com/Info/ID-your-Mac/2...
by
Add a comment
Chosen Solution
Sounds like your computer can't find the system that it want's to startup ... Try your Install dvd and restart holding down the option Key. you should abe able to see your harddrive's operating system choose it and let it boot up completely.. Then go to System preference / Startup Disk and make sure that your System is Chosen.. Restart and remove the Install DVD...If your Install DVD is the only option you have to startup your computer.. you might have to look at a new hard drive or reformatting and reinstalling the system...
Score 1
Add a comment
Most Helpful Answer
This can also be caused by a corrupted system folder. Boot from the CD holding down the "C" key and start to install a system, a couple of screens later the pull down menu appears. Open "Disk Utility" and see if you can repair the drive. If you can see the drive and disk utilities doesn't fix it then try installing a new system. If you can't see the drive then you probably need to replace it. Can you tell me which G4 you have?
Score 2
1 Comment:
The menu bar will show on the second screen of the installer. Right after the select a language screen. Disk Utility is located in the Utilities menu off that bar.
by
Add a comment
Usually however, this is because of a fried drive, try as olsonm suggested to boot from your drive, but if you can't it's probably fried, and you should boot from your install dvd to check the drive. You may be able to do some salvaging, but you probably need to replace it and maybe run data recovery.
Add a comment
Add your answer
rodney bolton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 8
All Time: 1,945
