2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Keyboard backlight does not work
Hello,
I changed the motherboard on my MBPR and the keyboard backlighting does not work. Is there another cable especially for the backlighting?
The keyboard works, but the backlighting doesn´t.
Update (03/17/2021)
This is My MacBook. But I can Not find the cable…
Add a comment
Most Helpful Answer
Yes there’s a small cable that connect the keyboard backlight to the logic board. It’s located hinges side to the left of the logic board. It’s very easy to forget to lift up the cable over the logic board during installation. Check the board you should see the small connector. If you don’t see the cable clipped on the connector it should be right there under the logic board.
Score 1
Add a comment
Looks like you still have it tucked under the logic board!
Add a comment
Add your answer
Eric Reinhardt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 18
All Time: 146
