Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
873 Questions View all
DIY repair gone wrong
Hi guys. I bit off a more then I could chew attempting a housing swap on my iPhone 8. Everything works fine but the bottom microphone (calls and voice memo mic). I ordered a new charging port assembly with microphone attached assuming the old was broken but same thing happened again. No voice and a horrible static noise. Have I missed something???
Add a comment
1 Answer
There are 4 total mics in the iPhone 8 plus. Two at the bottom on the charge port, one at the top by the ear speaker, and one by the rear facing camera.
The two on the port are used for I believe Siri and when talking on the phone using the ear speaker. When you switch to speaker phone, it uses the mic at the top by the ear speaker and I believe voice memos uses that one as well. So your next step should be to replace the front camera assembly as that is what that top mic connects to. Keep in mind that when you replace that assembly, you’ll lose TrueTone unless you can reprogram it with a special tool.
Add a comment
Add your answer
Nui will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 68
