Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Why is my earpiece not working?
So I fixed my iPhone a while back and I still remembered that before I had done the fix, the earpiece worked perfectly fine. However, now that the phone is fixed I dont hear anything from the earpiece whatsoever. The only means of communication through the phone are either using the speaker phone, bluetooth, or just headphones. I am contemplating on getting a new earpiece to see if that'll work, but I'd rather ask first to see what you guys think. Other than that everything works great on the phone! So..any thoughts...
1 Comment
WHAT DID YOU "FIX" ON IT?
Did you try the quick inand out with the plug?
Or blowing it out with air in a can?
Tinner
by
Add a comment
1 Answer
Chosen Solution
have you try with the loud speaker . then may be a earpiece or flex is not properly connected to logic board. check the connecter no 3 is properly connected . if connected then open the display assembly there you will see the small piece of iron see:
iPhone 3GS Display Replacement
see the step 11 you will see a small screw holding that remove and try gently remove that portion then you get the earpiece . check with multimeter whether is working or not or just change it ..
Score 2
Add a comment
Add your answer
Gerardo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,045
