2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
941 Questions View all
Need hard drive image. No video.
I'm having the dead video problem as well but don't care about the laptop itself. I am looking for a way to get the data off the hard drive without any video. Is there a way to do it remotely from another computer or perhaps pull the drive out and use an enclosure?
Add a comment
Chosen Solution
Use Target mode. Hook it up to another Mac via a firewire cable and start it up holding down the "T" key. The hard drive icon will show up on the screen of the other Mac.
Score 4
Add a comment
you can pull the drive out install in an enclosure and use Linux or another mac to get your data. I am assuming you have no video of any sort.
You can also remote into the laptop, only if that option is currently setup. ( SSH etc).
You may also want to check out the nvidia recall for this laptop. ( you can check at the apple store to see if your laptop qualifies, if it does, it will be repaired for free).
Something i would look into, i have had a few laptops fixed under this recall and once done, would solve your current problem. ( Only takes couple days for apple store to replace the motherboard in most cases).
Score 2
Add a comment
Add your answer
jason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 390
