{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
Display distortion at certain lid angle, horizontal lines
Display distortion at certain lid angle.
Is it possible that there is loose contact somewhere (where?)?
How to access display connector?
https://youtu.be/YmD5Gw0-mQ4
Add a comment
1 Answer
Chosen Solution
Ouch! Not good!
Sadly, there is nothing you can do to fix this other than replacing the display assembly MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here’s the guide MacBook Pro 13" Touch Bar 2017 Screen Replacement
Apple altered the design in the Touch Bar & Fn systems of the display splitting the T-CON logic from within the lid to the uppercase in doing so they extended the LCD lines via a set of ribbon cables connecting to the T-CON board in the case. Sadly these ribbon cables are soldered to the two parts and not serviceable which is why you need a new display assembly
Here’s a more detailed view:
The Purple ribbon cables are the ones affected here. Either you have a damaged cable or you got wetness into the T-CON logic within the metal can.
Most of the time we see Blue cables fail FlexGate when’re the backlight cable goes and the iSight camera which is a mirror on the other side.
Replace a display compatible with a 2016 or 2017 model A1706 or A1708 MacBook Pro 13" Retina laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism. Part #661-05096. Image
Product
$454.99
Score 1
Add a comment
Add your answer
dmitry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 146
