2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Questions View all
Power Issues ( Not Battery)
Hi - my batter was running down very quickly and chargers I kept buying stopped working. I replaced the battery but the battery is still draining quickly with the new batter, and I’m getting the message ‘service batter’, and also another charger has died. So this isn’t an issue with the battery itself as I replaced it. What could it be? Logic board? I’m going to take it into the apple store this wee but thought I would ask to see if anyone else had the same issue. Thanks
2 Comments:
If you can, let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question with the charger connected.
by
Thanks Dan - I've edited it with an image requested of the app screenshot!
by
Add a comment
1 Answer
Not good ;-{
This battery is bad!
You need a new one. I would contact the seller of the battery for a warranty replacement.
Your charger is working as wee can see its charging with 17.5 Watts of power.
I would also check your charger as many knockoffs can damage your systems charging logic as well. But that doesn’t look like your issue right now.
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
While I fully understand the cost of a real Apple unit is more, the cost in the long haul is more with a knockoff!
Please get the correct REAL charger directly from Apple or from an authorized dealer Apple 85W MagSafe 2 Power Adapter (for MacBook Pro with Retina display) The ones sold on Amazon and eBay are 90% fakes! Even when they tell you it’s real its not!
1 Comment:
Thanks for the reply! I think it may well be the battery being bad but I've replaced it twice in the past few years, and still had the same problem with chargers dying and power being lost quickly. I've only used official mac chargers, never the cheaper ones , which I was aware of the dangers of. I'm taking it down to the Mac store to get it looked it so hope they will be able to confirm the exact problem .Thanks again :)
by
Add a comment
Add your answer
Peter H will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 22
