The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Questions View all
replaced my I/O board and now speaker not working
Replaced my I/O board with iFixit replacement which consists of the power, USB, and headphone ports, to fix the issue I was having of my Macbook Air not charging. Good news is that it is now charging! Bad news is the speaker no longer works. I did have to disconnect the speaker connection to replace the board but did not damage it and securely plugged it back in. Is this a PRAM issue?
Add a comment
1 Answer
Chosen Solution
As always first try and reset SMC, NVRAM and PRAM. If nothing of that is working you probably didn’t connect the speaker right or you damaged connector.
Score 1
3 Comments:
Thanks Uros! Currently waiting for the new battery conditioning process to finish up. Will then perform the resets you mentioned and let you know.
by
Resetting the PRAM fixed it thank you! did not try resetting the SMC or NVRAM.
by
@koberlin1 Im happy I could help you!
by
Add a comment
Add your answer
Kent O will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 36
