2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Questions View all
How do I fix colored lines down my screen caused by pressure?
My laptop was open and I had been using it. I went to push the screen back a little and placed my hand around the side of the screen (so my thumb was on the screen and the rest of my hand was on the back (in picture). Suddenly a bunch of lines popped up tracing to where my thumb was and have not gone away in weeks. The glass itself is not broken so I think the issue is underneath. Is this fixable? How expensive would it be to fix?
Score 1
1 Comment
Same thing happened to my school computer I don't think you can fix it yourself they are taking mine to get fixed and its gonna be 550 dollars
by
Add a comment
Chosen Solution
Sorry to tell you the back glass (LCD panel) is cracked!
I often see this happen when something like a pen or pencil was resting on the keyboard and the lid was closed on it.
You’ll need a new display assembly 13” Retina MacBook Pro Display Assembly, Apple P/N 661-7014 and here’s the guide you’ll need to follow MacBook Pro 13" Retina Display Late 2012 Display Assembly Replacement
Score 2
3 Comments:
Thank you so much!
by
My brother has an old Macbook Pro from early 2011 (the one that still had the disk drive) but it is very slow . Can I take his LCD screen and put it in my Retina Macbook Pro
by
@sabrinabruno3 - Sadly, you can't use your brothers system for parts. There is too many differences for it to work.
Just like cars which look alike from the outside one uses gasoline and the other uses diesel! All you'll do is damage the engine if you put in the wrong fuel into the wrong car!
by
Add a comment
can i know how much would it cost to repair this screen so basically what happened is a usb was between the lid and the keypad and i closed without noticing and boom i have got this cracked screen with lines on it
does it require a full screen replacement
what would the cost for repair at an apple store
Add a comment
Add your answer
Sabrina Bruno will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 82
Past 30 Days: 403
All Time: 14,486
