Xbox Turns on But No Display Output
I have an Xbox One S that will turn on but not output any video. I tried different cables, tv's and ports, and none of that worked. I changed the HD to a known good one and I also replaced the retimer chip. I think the Xbox isn't booting correctly because I cannot turn of the xbox using the controller (by holding the button) I tried booting into the low res mode as well as the troubleshooting menu. None of these work. I tried doing an OSU (Offline system update) and this didn't work either. The HDMI filters are working and the retimer chip was replaced so I am really stuck here. Any help is greatly appreciated.
Did you resolve this? Before I replace the HDMI retimer IC chip and get the same result. As you did I tried all reset functions with nothing. Took out hard drive and powers supply and tested both ok. When it turns on there is no hard drive sound only a sound of the optical drive with a click every 10 seconds or so but nothing else and does not shut down itself.
by Daniel Geddes
