The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
426 Questions View all
Xbox Turns on But No Display Output
I have an Xbox One S that will turn on but not output any video. I tried different cables, tv's and ports, and none of that worked. I changed the HD to a known good one and I also replaced the retimer chip. I think the Xbox isn't booting correctly because I cannot turn of the xbox using the controller (by holding the button) I tried booting into the low res mode as well as the troubleshooting menu. None of these work. I tried doing an OSU (Offline system update) and this didn't work either. The HDMI filters are working and the retimer chip was replaced so I am really stuck here. Any help is greatly appreciated.
1 Comment:
Did you resolve this? Before I replace the HDMI retimer IC chip and get the same result. As you did I tried all reset functions with nothing. Took out hard drive and powers supply and tested both ok. When it turns on there is no hard drive sound only a sound of the optical drive with a click every 10 seconds or so but nothing else and does not shut down itself.
by
Add a comment
1 Answer
My experience with Xbox S’s and display issues are it’s either the Hard Drive needs replacing, or it’s the HDMI transmitter chip if your HDMI port is visually fine. When you replaced the hard drive did you do the formatting it needed?
Add a comment
Add your answer
Luke S will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 986
