Damaged diode
In my pictures the very last one, there's a red arrow in the bottom right corner, it's pointing to a part, I think it's a capacitor..
you can see the pictures here http://s1223.photobucket.com/albums/dd51...
Does anyone know where I can purchase one of these? or where I can find one online?
5 Comments
Junior this is your 3rd question on the same problem, same laptop. You still have not come back to your first question with the dimensions of the component. Why are you now thinking it is a capacitor and not a fuse?
by ABCellars
You have a picture up there with a red arrow pointing to it. The component is dark with white lines on one end. What is wrong with it? That is a diode.
by ABCellars
I was look at the board and found a crack, in the diode next to a plus sign on the diode.
Someone told me even if I replaced the blown fuse, thats theres something else cause it to blow, and will happen most likely again. I might just send it to be repaired..
by Junior
dimensions of the component, Hard to get the dimensions of the component, when everytime I touch the component, it falls apart, very brittle..
by Junior
The white one is falling apart? There is a metal plate on either end of the component. Get the measurements off of them outer end to outer end.
by ABCellars
