Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Why can't I seat display cable
I bought a second LCD display because I thought I may have done something to the cable end coming into the unit. It doesn’t seem to be it. I’ve no power at all to the LCD though I have an external display, not only is no power reaching it, it isn’t recognized by System Preferences. This is my first MacBook repair. Any and all tips appreciated.
1 Comment
Can you take a few pics so we can see what you are encountering, post them here Adding images to an existing question
by
Add a comment
1 Answer
Chosen Solution
Sadly the socket was damaged somehow. It looks like someone pulled straight up Vs sliding out the tang to the side as outlined in the guide MacBook Pro 15" Unibody Mid 2010 Display Replacement as stated in Step 15.
Sadly its time for a new logic board as being the easiest fix, otherwise you’ll need to find someone with the needed skills and tools to replace the connector, but that still assumes the logic board is good, that’s a large gamble here.
2010 15” MacBook Pro Logic Board 2.66GHz i7, Apple P/N 661-5480
2010 15” MacBook Pro Logic Board 2.8GHz i7, Apple P/N 661-5803
Here’s the guide you’ll need to follow to install it: MacBook Pro 15" Unibody Mid 2010 Logic Board Replacement
MacBook Pro 15" Unibody Mid 2010 Logic Board Image
Guide
Difficulty:
Difficult
30 minutes
MacBook Pro 15" Unibody Mid 2010 Display Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 2
1 Comment:
Thanks ! The dummy was me ! Iswore I came out parallel to the board, but either i did pull up or my explorations wounded it.
I'll follow the links to check prices, but I need a part # for the connector just in case. The rest of the system is fine.
by
Add a comment
Add your answer
James Walker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 84
