How can I replace the bottom microphone?
I damaged the bottom microphone, but cant find the module to replace it. Where is it located, and how do I replace it?
The reason why you probably can’t find the replacement part is because unlike previous models, Samsung graciously soldered the charge port assembly to the motherboard on the S10 series. Typically the microphone is connected to the charge port assembly which was a separate daughter board. You’ll need to find someone who specializes in mircosoldering if you want this repaired.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 38
All Time: 3,328
