Why doesn't my new battery hold charge
New battery installed in iphone 7 plus. However, it’s not lasting more than a few hours (less than half a day). Is there anyone else who ran into this?
Several things can cause Battery Drain issues. You will need to isolate some variables in order to get a better understanding of what is wrong. The problem could be a bad replacement battery, excessive current draw from one of the modular components (camera, button, screen) or it could be a problem on the logic board itself.
Here are some things to try:
It could be a bad replacement battery; there are lots of cheap batteries on the market.
You could have excessive current draw from one of the modular components; for example, the backlight, a camera or a sensor. You may notice a hot spot on the phone or screen.
If that doesn’t make a difference, then you should try to disconnect the screen to see if it’s the screen or the logic board
You may have a damaged logic board. This will require a micro-soldering repair and is not DIY. Drops, bends, water damage or using poor quality charging bricks and cables, can cause this.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 68
