The larger version of Samsung's flagship phone. Released March 2018.
130 Questions View all
Can I use 95% ethil alcohol instead of Isopropyl?
I cant find Isopropyl alcohol in my country. I want to make glass only repair on my galaxy s9plus. After removing outer glass can i clean adhesive on LCD using ethil 95% alcohol(ehtanol)??
Add a comment
Chosen Solution
Sure you can. I use methanol. Both are more volatile than alcohols diluted with water. I use a syringe to shoot methanol under the glued in batteries on MacBook Pros. The iFixit kit uses acetone.
Score 1
Add a comment
Most Helpful Answer
Hi,
I would be wary about using Ethyl alcohol to clean electronics but that is just me.
Here’s a link that may help you to decide. Although they are talking about laboratory grade Ethyl alcohol and not standard grade.
Is “rubbing alcohol” (usually available from pharmacies) available where you are? If so you may be able to find some “rubbing alcohol” products that are ~70% IPA and water which may be less risky to use on electronics than Ethyl alcohol. Just a thought.
Score 1
Add a comment
Add your answer
giorgi dzidziguri will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 39
All Time: 1,633
