Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
Camera focus after case replacement
I recently replaced the assembly of an iPhone 7+. However I’m noticing that the camera images are blurry regardless of zoom setting.
When I take the phone apart, and remove the camera from the “port” it sits into, the camera is no longer blurry (I tested while the phone was apart and camera lens moves in and out and focus is perfect). As soon as I put the camera back into it’s spot, the camera is blurry. The lens is perfectly clean.
I have a feeling that when the camera is placed in the port, the actual camera lens can’t “zoom” and physically move.
What am I doing wrong?
Add a comment
1 Answer
Most Helpful Answer
Same problem here, after replacing the glass at the back of the rear camera with the middle part also, couldnt fix de alignament bracket properly , and the conclusion is no focus on the camera, also the selfie camera no longer works. So, i sugest a new case, original, is the only way to fix these problem, this what i will do.
Score 1
1 Comment:
Hi, were you able to fix this problem? i have a similar issue with my 7plus
by
Add a comment
Add your answer
SynPDX will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 298
