Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
Colored lines on screen
So I'm debating buying this MacBook due to it's cheap price because of an issue. It has lines across the screen, it doesnt look like the LCD is cracked. Could it just be a loose cable on the motherboard?
Add a comment
This is a problem with the lcd. Unfortunately, it looks like it needs to be replaced
Add a comment
@ran9aa - As the lines are equally spaced and repeat across the image this a display assembly failure.
Within the display assembly you have the LCD panel and you have some logic which converts the signal from the logic board to the needed signals the LCD needs we call this logic a T-CON board. In this model it is part of the display assembly MacBook Pro 13" Retina (Late 2013-Mid 2014) Display Assembly and here’s the guide to put it in MacBook Pro 13" Retina Display Mid 2014 Display Assembly Replacement
So depending on what the cost of the system and its specs it maybe worth it, knowing you’ll need to fix it.
MacBook Pro 13" Retina (Late 2013-Mid 2014) Display Assembly Image
Product
$449.99
Add a comment
Add your answer
Jakob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 78
