The first model of the iMac line of personal computers made by Apple. The iMac G3 was produced between 1998 and 2003.
92 Questions View all
Question Closed
cannot log in
i recently bought a older mac from the second hand shop, it already had an administrator on it, i tried to set up my own acct and it took it but when i try to log in i cant its not recognizing my password and since i dont know the other one that was on i cant even log in to try to fix it. it is one of the older blue ones with the built in drive all in one kind can u help,
Add a comment
Chosen Solution
Just boot from the install disk it hopefully came with, and follow through the instructions to reinstall.
3 Comments:
hi and thanks again i bought it at a pawn shop it didnt come with any cds i was able to get in at first but it was when i added myself as a guest acct that this happened it does show the original admin and me but for some reason my password is not being accepted but the pi and hint are its strange and i dont know the original owners pass of course and I since i cant log in i dont know which osx it was useing when it starts up it just says mac osx
by
I suggest you buy the latest OS you can run then on ebay or amazon (probably Tiger or Panther) and use that as an install disk. Plus, you'll update it if it's outdated.
by
Here's one trick that may work though:
1. Boot into single user mode (press Command-S at power on)
2. Type fsck -fy
3. Type mount -uw /
4. Type launchctl load
/System/Library/LaunchDaemons/com.apple.DirectoryServices.plist
5. Type dscl . -passwd /Users/username password, replacing username with the targeted
user and password with the desired password.
6. Reboot
by
Add a comment
Most Helpful Answer
Reformat the hard drive and install a new system.
Score 1
3 Comments:
thank you for the quick response i appreciate the help i did add some more info and a question but i put it in the wrong place i found a model #5521AND A SERIAL #YMO450PGJAU
by
This is a link to the Apple technical specs page for your iMac
http://support.apple.com/kb/SP64
It appears that you have a 300-500 MHz CPU
The maximum RAM for this machine is 1 GB (2-512 PC100 DIMMs)
The RAM does not have to be installed in pairs.
Do not buy RAM until you determine exactly which machine you have.
Go here to here you determine that:
http://www.everymac.com/systems/apple/im...
It will rum system 9.04 - 9.06 in classic mode
Other sources state that it will also run 10.2- 10.4
My experience tells me that I would not take it past 10.3.
These install disks can be bought cheaply on eBay.
Hope this helps
by
your an angel and i thank you have a super day
by
Add a comment
thank you for answering me so quickly i see the pics on here and it is a imacg3 blueberry, im not sure what reformatting means or how to do this or which operating system i should buy to reinstall if its not to hard i can probably do it or my son can if it is i will need to take it in it says it runs mac os but i see there are several kinds im not worried about lost data because i havent put anything except a few songs when i first bought it
Add a comment
Hope this helps
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 799
