1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Temperature Sensor Failures and possible fixes
Running ASD on MacBook Air, getting failures on TB1T and TB2T Temperature sensors. Does this require a complete logic board replacement, or is there something less drastic that might fix this?
Add a comment
1 Answer
Most Helpful Answer
Your error is battery failure!
  • TB1T - Temperature - Battery TS1 Temp
  • TB2T - Temperature - Battery TS2 Temp
Time to replace your battery MacBook Air 13" (Late 2010-2017) Battery and here’s the guide MacBook Air 13" Mid 2012 Battery Replacement
An aftermarket replacement battery compatible with a MacBook Air 13" laptop. Image
Product
$69.99
Score 1
2 Comments:
Thank you for your answer! Would I get this kind of reading with a third party battery? I replaced the original (or, maybe, second Apple battery) with a battery from OWC just last month, and by all other indications (coconut battery, etc.) it is running fine and within normal temperature parameters...
by
Apples onboard diagnostics is broken presently after you upgrade to Mojave the newest version of EFI breaks it! As such I haven't been using it ;-{
What I have seen besides a bad battery is liquid damage on the U5810 chip which is where the inputs goto.
So if you've replaced the battery with a known good one and you are still getting the error then I would focus on the logic board.
by
Add a comment
Add your answer
Clay Hummer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 344
