Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36474 Questions View all
THE DEFINITIVE ANSWER ON BATTERY APNs
Hi guys,
I'm fairly new to iFixIt, but I have been repairing iPhones (in the UK) for nearly two years now, so I'm very experienced with hardware repairs. However, one thing that's always got me confused is the APN numbers for batteries, and the real headaches they cause!
It seems that every iPhone I see has a different APN printed on the battery, and in my experience, replacing it with a battery of a different APN causes it to either not power on properly, or cause "Error 29" when trying to restore. These issues are fairly well-documented on here, and I accept that it is indeed an issue, solved by replacing the battery with the SAME APN. Fair enough.
But, here's the thing, how do people "get away" with DIY battery replacements? SURELY it can't just be chance that when they order a replacement battery, it just happens to match up to the APN of the battery currently in their iPhone? Because if it doesn't - this causes many problems as described above! I must have seen no less than 7 or 8 different APNs for 3G and 3GS batteries, so how can people possibly survive a battery replacement when they don't know the APN of their battery, or don't even know about the "APN story" at all?
Today, I went to replace a battery in an iPhone 3G, which had APN 616-0366. I only had APN 616-0428 iPhone 3G batteries, so I thought I'd give it a go anyway. Lo and behold... it wouldn't boot up! It got stuck at the Apple logo, and then started fading really slowly and powering off - obviously this was caused by the different type of battery I had just installed. I took out the 0428 and put the 0366 back in, and it worked just fine again. This situation has happened many times before with different APNs.
So, I was wondering if anybody had some sort of list of all the different APNs that are available, and which model of iPhone they work in? Surely big iPhone repair companies don't have stock of every single APN - or do they? If they do, then how does the logic work with DIY replacement batteries from eBay and the like? Do individuals always face problems when the wrong APN battery for their iPhone gets delivered?
Any clarification would be GREATLY received!
All the best,
Josh.
Score 3
2 Comments
Do you know if it is important for iPhone 4?
by
No. Based on what we have found the APN has not been an issue for the iPhone 4 thus far.
by
Add a comment
Chosen Solution
Josh, with the iPhone battery APN issue, the APN for the iPhone 3G has little to no bearing on the boot sequence that I have seen. However, with the iPhone 3GS the magical APN appears to be 616-0435.
Error -29 was not an issue until the release of iOS 4. It was then then that Apple decided to execute their version of Order 66 if you will. This error has caused headaches in the lives of many like unto yourself. I don't know all of the variety of the APN's, but as I said the 616-0435 APN has solved the issue for the iPhone 3GS Error -29.
If you are experiencing an issue with a 3G encountering the Error -29, you may be using a 3GS battery, but I personally have seen no issues with the iPhone 3G battery and Error -29.
Update
As of 2012, the following APNs are also compatible: 616-0431, 616-0432, 616-0433, 616-0434, or 616-0435. We have tested these and have not had any issues with Error -29.
I do believe the days of endless woes of Error 29 are over.
Score 3
3 Comments:
obviously this is an issue- and knowing compatibility WOULD be very helpful. I just tried to replace a 0428- with a 0366. it would not even begin to turn on unless it was plugged in, and then would start booting and then stop and turn off after 5 - 10 sec. put the 0428 back in (which looks newer than the one they sent- the 0366 solder connections and wiring in the ribbon is thinner / different- and it works fine. now to get "New Harbor" to send the right one/ refund my $5
by
I remember there was an issue way back. Check on here Try to restore get a error 29
by
Also, it sounds like you may have purchased a battery for an iPhone 3G instead of an iPhone 3GS.
by
Add a comment
same issue, i replaced the original with a 0347 and it would power up, i'd get like 30 seconds and then reboot itself, put the original back in, works fine. going to send it back for a replacement and give it one more shot before upgrade my phone.
Score 1
Add a comment
Never has this problem, the batteries have always worked
Score 1
Add a comment
my iphone 4 has got a problem in charging. it charges very slowly (it takes more than 10 hiurs to be charged 100%). waht is the possible solutions?
Score 1
Add a comment
So I just tried replacing the battery in my 3gs. The replacement battery which was the -0435 didnt work. It would power on but it wouldnt charge. Im not sure what the APN is on the original battery. Im really frustrated with this.
2 Comments:
David from what i understand there is a tiny fuse on the board that might be damadged it is near the do not remove sticker.
by
A larger view of that fuse could help me. I have also replaced my battery with a 0435. The phone worked once I got past the white screen of death. The phone worked until the battery charge depleted. I used a wall charger a computer neither charged the phone. About to send the battery back and order a 0431.
Any suggestions?
by
Add a comment
Just a note: I replaced the 616-0435 by a 616-0435, same VPN as well. However, that didn't work, it refused to charge in three different devices. So, I put in the old battery again -> everything is fine again....very frustrating
Add a comment
does this happen and in iphone 4 running on ios 6xx ??? coz i have an iphone 4 32 gb and want to replace the battery and i know about the apn isue on 3gs but i just hope it is not occuring on 4
3 Comments:
no it does not:-)
by
thnx man ... i was kinda worried (despite the fact that never heard about apn problems on iphone 4) it was worth asking :P thnx again for your reply
by
you are welcome, good luck.
by
Add a comment
Add your answer
josh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 41,421
