Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
MacBook Pro won't power on after I remove the battery
I just removed the battery from my MacBook Pro, and it will not turn on when plugged in. The battery removal was necessary; it was very swollen. I have the original charger, and I have plugged the MacBook in as if I was charging it. However, it will not show any signs of turning on, besides the green LED on the charger. Does anyone have any recommendations as to how I can fix this issue?
1 Comment
So you took the battery out and then put the same battery back in, is that correct?
by
Add a comment
Most Helpful Answer
Time for a new battery!MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery and here’s the guide MacBook Pro 15" Unibody Mid 2010 Battery Replacement
Your system won’t start up without a battery installed which is working.
MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery Image
Product
$89.99
Score 1
Add a comment
Not all macbooks need to have a battery in to turn on when it is plugged in it should work! It can depend on the max wat of your charger in that factor of what you had tried to do!
Laptop is having other power issues remove some ram reseat test ram
It could be some other bad hardware
Bottom plate should be on not screwed down
2 Comments:
The Airs & Retinas will work without a battery the Unibodies need the battery.
by
Do you have a fresh battery?
by
Add a comment
Add your answer
Gavin R. will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 92
