2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Help! MacBook doesn't boot properly after battery swap
HELP, I swapped the battery as described by the instructions, step by step. Don't follow the guide, removing the motherboard is way to risky… I now have apparently damaged the logic-board (according to apple genius). When I try to turn on the macbook the initial loading-bar takes way longer and at about 3/4 the screen shuts off. Does anyone know where ì could look for help or what to do?
Additional information:
- if I boot to the bootcampscreen (pressing r) the display doesn't die, until I actually try to boot…
Is there a way ì can save my beloved mac? Thanks for any help.
Add a comment
1 Answer
On recover page click top left to check start up disc if it see hard drive you will need to load os Sierra on it boot to flash reload your os to fix
Add a comment
Add your answer
Simone will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 59
