Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
134 Questions View all
Display got red line in some cases
Hello everyone. I have a problem with the display. When I am opening and closing the top, some red blinks appear. I attach a screenshot of this
The interesting detail is that I got repaired this Mac like a 4 days ago, the reason why I went to service center was also a problem with the display! But it was a bit different, there is also a screenshot of that
The support told to reset Reset NVRAM or PRAM with this https://support.apple.com/en-us/HT204063 instruction. For now it’s gone, but I don’t believe that it’s gone forever
2 Comments
Did they replace the display?
by
Yes, really. As they told me, they replaced the whole top case of it
by
Add a comment
1 Answer
Most Helpful Answer
Ouch! Your display has a crack! Looks like something heavy was dropped on the lid or something sat on the system.
I hope you took AppleCare+ support contract as this will cost you!
Luckily its not very hard to do MacBook Pro 13" Touch Bar 2017 Screen Replacement We don’t currently have a direct guide for your exact system but this one will get you there.
Score 1
2 Comments:
Thank a lot, @danj! I've already replaced that display, but that's interesting to know this fact. Could you please take a look on the first screenshot? That's the case with the new display
by
@birdi7 - The image is too blurry to see anything in your first image. How about trying again maybe you want to make a short vid. Use a tripod or other means to steady the camera/iPhone you might want to increase the light as well, just be careful the light is not reflected off the screen.
If this is a new display, then they may have damaged the ribbon cables that feed from the T-CON board to the LCD which is mounted within the uppercase.
The newer 2016 models moved it from the display assembly down to the uppercase which I think was a bad design decision. The number of lines is more and the flexing puts it at risk. We've already seen an issue with the backlight ribbon cable as well as overheating T-CON boards when people block the vents.
by
Add a comment
Add your answer
Egor will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 5
All Time: 578
