1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Questions View all
Question Closed
Can I replace a iMacIntel 17 optical drive with a 2nd HDD?
Can I replace a iMac Intel 17" optical drive with a 2nd HDD?
I would want 1 ssd sata and 1 Hard disk 2.5 (sata o pata?)
Bus ATA:
MATSHITACD-RW CW-8124:
Modello: MATSHITACD-RW CW-8124
Revisione: DACH
Numero di serie:
Unità amovibile: No
Protocollo: ATAPI
Numero unità: 0
Tipo di socket: Interno
Polling a bassa potenza: Sì
Spento: No
Add a comment
1 Answer
Chosen Solution
Yes, you can have a second drive by using a Optical Drive Adapter. You can have either a one ssd sata or one Hard disk 2.5, you can't have both. Please give us the last three figures of your serial number (found on the bottom of your stand) so we know exactly which machine you have and direct you to the correct part.
Score 1
1 Comment:
excuse for my very bad English.
I would want 1 ssd (64Gb) to the place of the 3,5 hard disk and 1 Hard disk 2,5 to the place of the optical unit
The serial number is: CK720027WH4
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 439
