Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
iMac Screen Flickering after SSD install
Hi there,
I recently installed a new SSD into our 2011 iMac to replace the hard drive.
All was working fine, however since screwing the LCD back in, the screen flickers consistently.
The brightness is set at maximum, if I reduce the brightness using the keyboard, the screen goes fully black. However I can still see an image behind by using a flashlight directly over the screen. I assume the backlight is not working.
I also purchased and installed a new display ribbon cable however that has not worked. Can anyone suggest anything?
Thanks
Score 1
2 Comments
@mayer
Hi! So I replaced the driver board. The flickering still occurs, however I have discovered that the LCD flickers constantly on max brightness now, but on minimum the LCD stays on? Before all I saw was black when I tried to reduce the brightness even by 1 bar.
I'm thinking LCD or the PSU? Can I measure anything with a multimeter?
by
Bump - any ideas?
by
Add a comment
1 Answer
Chosen Solution
Time for a new LED driver board:
iMac Intel 21.5" EMC 2428 LED Driver Board
iMac Intel 21.5" EMC 2428 LED Driver Board Replacement
Replace the circuit board assembly that powers the display backlight in a Model A1311 Late Mid 2011 21.5" iMac. Image
Product
$29.99
Score 2
2 Comments:
@mayer
Hi, thanks for the response.
What is the likelihood that it's the driver board? Like I said I just repositioned the screen, (everything was fine) then the flickering occured after next boot.
Some times when I put the new ribbon cable in I get a flash then a black screen, other times it's flickering.
by
On older machines it would be the inverter. The part is cheap and your best bet.
by
Add a comment
Add your answer
Thomas Govern will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 496
