iBook G4 14 1.42 GHz charges battery, don´t turn on
Hi, I replaced DC-In Board reading Ibook G4 14 Troubleshooting (problem fit with "Bad DC-In Board" section.
Previously I bought a new power adapter and a new battery.
Battery ran, but power adapter didn´t charge it, so I bought a new DC-In Board and I replaced it following your instructions.
But now, battery seems to charge, I put it almost empty and now it has three green lights (although they appear and disappear, intermittent)
However, when I press the power button, computer does nothing, no turn on, no hard drive sound, it seems dead.
What would the problem? I don´t think board problem, cause it ran good before change DC-In Board. (It ran good with new battery 50% charged I mean, with new power adapter, computer did not turn on without battery)
Thanks.
Score -1
Add a comment
Chosen Solution
Try to reset the PMU (power manager unit).
Disconnect the ibook from the AC adapter, remove the battery and push on the power button for at least 5 seconds then reinstall the battery, plug the ac adapter and try to power up the machine.
Score 3
4 Comments:
It almost works. I can start now, computer works with AC adapter (without battery too). But when I see About this Mac, More Info - Power, it appears Battery not charging. First time told me too there is 1 Cycle Count.
I turned off Ibook and I left power adapter trying to charge battery. Computer told me it has less than hour remaining before do this.
Now, battery is 43%, there are three green lights when i push battery button, and in Apple Menu appears 2 Cycle Counts.
It appears this too: "AC Adapter can´t charge battery : Yes"
Amperage shows 0
Voltage shows 14515
At least, I can use Ibook with AC, but it sounds something is still wrong.
Another ideas what can I do to fix it completely?
Thanks.
by
Is your battery a cheap generic one from China ? If so be aware that these batteries often have problems. Could you check it on another ibook ?
by
Yes, is this: http://cgi.ebay.es/ws/eBayISAPI.dll?View... I´ll try with old battery to make a proof. AC Adapter is from ebay too. At least I can use computer with AC Adapter.
by
With old battery Apple Menu say is charging. About Chinese battery don´t say it, but I´ve checked it charges too. Thanks, for your answer, problem solved.
by
Add a comment
The first thing I would do is reseat the keyboard cable. Sounds like you aren't getting a start signal.
Score 2
1 Comment:
Thanks for response. I´ll try.
by
Add a comment
Add your answer
diego will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,736
