Repair manuals and information for the Microsoft Surface book line of laptops.
Why isn't my surface book clipboard not charging?
I just bought a surface book from ebay. I let it charge for a few hours while I went to class, when I came back it said Batter 1: 0% and not charging. I’ve tried everything, from resetting to repairing using the surface diagnostic tool. Nothing seems to work. I even tried manually charging the clipboard. But it just won’t charge. If I let the clipboard charge for an hour then it shows 88% and shuts down immediately after I unplug it. When I attach it back to the keyboard it says 88% not charging, 75% not charging, until it reaches 0. The keyboard charges fine, the only problem is with the clipboard.
Add a comment
Chosen Solution
If you bought it second hand, go find the seller.
Score 1
Add a comment
Issues with laptops not charging correctly are usually related to a bad battery, a damaged charging port, or a damaged charging cord. Have you tried exchanging the clipboard’s battery and/or charging cord? This may fix the issue.
Score 1
Add a comment
It is so common problem, which needs to be solved and fixed. I faced it last month when I was preparing for my classes. I only finished my paper and lost it in a minute, it was the day before the deadline, so I run out of time and needed essay help. That is why I had to ask help from this https://www.aresearchguide.com/essay-hel... project, the paper was great and I got a good mark. But I had to pay money just because I faced this issue.
Add a comment
Add your answer
Hardy Man will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,525
