A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 Questions View all
PS4 Model CUH-1216B only has 2 screws, how do I open it
Hello, my PS4 Model CUH-1216B only has 2 screws on the back. Can you please explain how to open it. Since a few days it won’t start up again. Starting it, I only get a screen saying “connect the dualshock 4 with a USB-cable and next press the PS-key”, which doesn’t do anything. I got it once in safe mode and tried to reinstall everything, but then it crashed again and now I am stuck! Does anyone has an idea about what could be causing this? Thanks for your support.
Bob
Add a comment
Most Helpful Answer
If you have already exhausted all the options in safe mode with the full PS4 initialization firmware file downloaded into the USB then it’s going to be a bad hard drive.
Software update can fail with error code if the blu-ray drive is not working. As long as you can eject and insert discs into the PS4 the blu-ray drive should still be good.
PlayStation 4 Hard Drive Replacement
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket Image
Product
$29.99
Score 1
Add a comment
Press and hold the power button until you hear two beeps: one when you first press and another seven seconds later.
1 Comment:
i can't click on the other options except for number 7 , what should i do ?
by
Add a comment
Add your answer
Bisshop Jyr will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 13
All Time: 1,451
