Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Question Closed
intermitent unresponsive touch screen
i have an iphone 3g, i replaced the screen and touch screen, it worked perfectly for 6 months, now the screen only works when i press the power button and the slide bar and cancel button apears, but when i tried to unlock the phone the touch screen doesn't work.
the display is fine
Add a comment
1 Answer
Chosen Solution
Your digitizer is failing. You need to buy a new front screen with attached digitizer for 3g iPhone. It is ususally just called digitizer but it will come with the front glass too. Also make sure it comes with the top and bottom adhesive strips.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 248
