Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530 Questions View all
fan sound and capslock light ok, but display and hd nothing!
When i turn on may macbook g4 14" the sound of fan start, the light of capslock turn on, but nothing happen. The display is black. I tried start with a "T" button, with another macbook. Nothing. The problem must be motherboard or hd? thanks. (is most important to me save the hd)
Add a comment
1 Answer
Chosen Solution
This is (most likely) a problem with the motherboard. I've had a couple Apple laptops die, and this is what they always do. Does the "F5" key turn on the "Num Lock" light? Your hard drive, and data should be safe, and you can remove the drive using this guide (I'm assuming that you're talking about a 14" iBook G4)
Score 2
1 Comment:
This is a symptom of a desoldered U28 chip on the logic board. No chime at startup and fan running as $@%$.
by
Add a comment
Add your answer
Rodrigo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 381
