Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
iPhone 7+ Touch Issues
I know there were issues with IOS 11.3 and that was resolved. I have recently been getting a rash of comebacks with touch issues with the 7+ and only the 7+. I buy the OEM screens from multiple vendors. The repair goes fine and the touch is working fine, but a few days or a week later, they will be back. I am at the point where I don’t want to work on the 7+. Any thoughts or ideas would very helpful.
Add a comment
1 Answer
Chosen Solution
The problem is with your OEM screens.
The 7/8 series original screens are made by several manufacturers (Toshiba, LG, Sharp) and each phone is calibrated to the screen it has installed. It’s important not to mix and match screens. So for example, if your phone had an original LG screen, you should replace it with an LG screen. This issue seems to be more prevalent on the Plus devices; they can be quite picky when it comes to replacement screens.
The only way to know which screen manufacturer you have is to look at the QR Code on the 3D Touch panel. However, even if you have a screen with the same code, it may still be a franken-screen. Lots of refurbish shops mix and match an LCD from one vendor, a 3D Touch panel from another, etc. All you can identify is the 3D Touch panel.
Check out this blog (not affiliated) to learn more. It explains how the different mix of products affects the reliability. It turns out that some franken-screens have a much higher prevalence for Touch issues than others.
Curiously enough, aftermarket screens don’t suffer from this issue at all. Unfortunately, they tend to have bland colours and in some cases poor construction quality. A good alternative is a SHARP In-Cell Technology (“in-cell”) screen.  They don’t suffer from the touch issues like other aftermarket screens, but they have great colours and are less expensive than OEM screens. They can be a bit hard to find but offer the best compromise. Different vendors sell them under various branding but they generally state “in-cell” somewhere in the description.
Score 4
Add a comment
Add your answer
seth swain will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 139
