In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
423 Questions View all
I cant enter my password in the log in because of keyboard malfunction
Out of nowhere, my macbook keyboard suddenly started malfunctioning. Its stuck on the shift key, because i cant type lowercase letters or numbers. The problem is, i cant log in to my macbook because my password has lowercase letters in it. How do i fix this?
Add a comment
1 Answer
Most Helpful Answer
Hello Patee,
You can try to clean the button with isopropyl alcohol in the off state.
Connect an external keyboard for now. If this doesn’t help, you have to replace it, by opening the system.
But only if you know what your doing. I’m sure there is a dissasembly manual here on ifixit.
Geetz mischakuh
Score 1
1 Comment:
Take a look at this How to remove and clean MacBook Pro Retina SHIFT key
Here's the guide to pull the bottom cover MacBook Air 13" Early 2015 Lower Case Replacement and here's the other guides as the 2015 is the same MacBook Air 13" Early 2015
by
Add a comment
Add your answer
Patee Reyes will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 565
